AutoDWG DWGSee Pro 2027 v6.61
3 383 posts 3 383 threads Dołączył: Nov 2025
26-01-2026, 22:24 -
[Obrazek: 494df68b8469d48c1eb39cdcc2e57e6e.webp]
Free Download AutoDWG DWGSee Pro 2027 v6.61 | 37.5 Mb
A light and fast DWG viewer & CAD, easy to browse, view, measure, markup, modify and print DWG/DXF/DWF files. Supports latest AutoCAD 2025 drawings.
What's new in DWGSee 2027?
DWGSee 2026 is more than a dwg viewer, it's a quick drawing editor, converter, version comparing tool.
Draw
Many objects such as line, polyline, circle, arc, text..., can be easily added into your drawing.
Modify
Objects like text, line, layer, block attribute can be edited, or right-click to change the object properties.
Annotation
Annotation objects include dimensions, notes..., commonly used to add information to your drawing.
More features
DWGSee DWG Viewer is a light and fast viewer, designed to browse, view, edit, measure and print DWG/DXF/DWF files.
Supported formats
Support AutoCAD .dwg .dxf .dwf files, version R14 to the latest 2025, and also can open raster image formats-.bmp .jpg .png .gif .tif.
Save as
Save drawing file to different versions of dwg/dxf files, includes R14- 2025, DWGSee has a build in AutoDWG converter.
Export (Pro version only)
Export drawing to pdf and raster images within few simple steps, good for distributing your designs, or drawing reviews.
Measuring objects (Smart-snap)
Measure length, angle, radius, area, click and get measured values. Easily and accurately click to select entities terminal, central or cross junctions.
Print and batch print
You can open up a DWG/DXF to print out, or, you can select many drawing files to print with few clicks, no need to open each of them.
Markup drawing
You can either retain .dwg and add comments in a separate markup file, or, you can add additional layers, lines and texts to the dwg file.
Compare drawings
Showing two versions of drawing in split windows, synchronize zoom and pan for both drawing, list and highlight differences in drawings.
Miscellaneous features
Searching text in drawing, save layouts to individual drawings, encrypting drawings and protects them with password...
Floating license available
In case your company has many workstations and most of time they are not running DWGSee, then the network license will save your cost.
Terminal server supported
Works for Citrix, XenApp... Window Terminal Server.
https://www.autodwg.com/dwg-viewer/
lco10.AutoDWG.DWGSee.Pro.2027.v6.61.rar.html
https://turbobit.net/p3puqzf4szbi/lco10....1.rar.html
